How to create a file node by click a button
Hi all:
I have a question,
Let's say I have a ROP OUTPUT DRIVER, I set up a button in it,
and I want the button to add a file node with correct file path which is the path form ROP OUTPUT DRIVER after click it,
what should I do? I'm new to Houdini scripting, so I have no idea where or how to write it.
Could somebody please show me how to do it?
Thank you.
Hi all:
I have a question,
Thank you.
If I understood correctly, you're trying to create a file node in a specified network path not on the file system.
If so, then there are 2 ways you can do this but you will need to get the path where you want to create the node.
In hscript:
opcf /obj/geo1 # parent path
opadd file myFile # command to create the node
In python:
myNode = hou.node("/obj/geo1") # parent path
myNode.createNode("file", "myFile") # command to create the node
Cheers,
Ron
In hscript:
In python:
Cheers,
Ron
Hi Rony:
Thank you for replying,
Sorry I didn't explain it clearly,
I'll explain with image, please see the attachment, hope you can understand what I was saying
Thank you so much
Edited by evilbear
You can do something like this in the callback field of the button.
file_sop = hou.pwd().parent().createNode("file"); file_sop.parm("file").set(hou.pwd().parm("sopoutput"))
Hi Graham:
Thank you so much.
  • 7 years later...
