Owl Posted July 3, 2012 Share Posted July 3, 2012 Hi, I've made Mandelbox in volume vops, but it has lots of noise unfortunately. Does any one have any ideas of how to get rid of it? in calculations or afterwards? mandelbox.hip Quote Link to comment Share on other sites More sharing options...
old school Posted July 3, 2012 Share Posted July 3, 2012 Some things to try: - Try a different filter and filter width on the Object. Default is Box filter at 1x1 which looks like you are using. - Step size, is it small enough to pick up the details in your volume? - No substitute for more voxels. Try a higher resolution volume. One voxel per pixel... Quote Link to comment Share on other sites More sharing options...
Owl Posted July 3, 2012 Author Share Posted July 3, 2012 (edited) this should probably go to rendering section, but its the same mandelbox so... i don't get whats wrong with the otl i've made out of previous scene, but: if i use it in volume vop its all good if i use it in cvex - it gets stuck at 1st iteration if i use mandelbulb by Jeff Lait in cvex its all good Edit: if i use non otl version of mandelbox - its all good mandelbox_cvex.rar Edited July 3, 2012 by Owl Quote Link to comment Share on other sites More sharing options...
bloomendale Posted July 4, 2012 Share Posted July 4, 2012 this should probably go to rendering section, but its the same mandelbox so... i don't get whats wrong with the otl i've made out of previous scene, but: if i use it in volume vop its all good if i use it in cvex - it gets stuck at 1st iteration if i use mandelbulb by Jeff Lait in cvex its all good Edit: if i use non otl version of mandelbox - its all good mandelbox_cvex.rar To accumulate C in foorloop you need to connect it to your suboutput. Quote Link to comment Share on other sites More sharing options...
Owl Posted July 5, 2012 Author Share Posted July 5, 2012 To accumulate C in foorloop you need to connect it to your suboutput. damn how could I've missed it, such a stupid mistake, thanks Its actually P that should be accumulated Quote Link to comment Share on other sites More sharing options...
