hbiz Posted July 20, 2012 Share Posted July 20, 2012 (edited) Hi, I ran a surfsect sop on some nurbs geometry using a user defined boolean (Keep Inside A & Keep Inside B ). The result looks good, however, when I select it in points mode, I see the point were supposed to be removed still floating. Anyone know how I can get rid of them? I've attached my hip file (houdini 12) Thanks for your time surfsect_question.hip Edited July 20, 2012 by hbiz Quote Link to comment Share on other sites More sharing options...
gaurav Posted July 26, 2012 Share Posted July 26, 2012 Anyone know how I can get rid of them? Generated surfsect boolean (still nurbs) is a function of two nurbs surfaces. It needs to have the underlying nurbs geometry to generate the result. Middle click on the surfsect to see that there are 2 surfaces. So to really clean that area you will have to change the way result is represented, ie Append a convert sop to make it poly AFAIK. Quote Link to comment Share on other sites More sharing options...
