hopbin9 Posted July 20, 2012 Share Posted July 20, 2012 Hi, I have a digital asset that uses a color ramp in the parameters, but I can't figure out how to set the defaults for it. As if it is now, when a new instance of the asset is used the ramp defaults to a two point black/white gradient. Which really isn't correct for the context of the asset. Is there anyway to set this? Thanks, Quote Link to comment Share on other sites More sharing options...
graham Posted July 20, 2012 Share Posted July 20, 2012 (edited) Ramp parameters (which are really a fancy multiparm block) are definitely lacking with the default settings through the interface. However, if you create the parameter, configure the points how you like and hit the 'Get from parameter' button on the parameter in the Type Properties it should save the state as the default values. You could also add an OnCreated section to your asset and configuring all the default points manually. Edited July 20, 2012 by graham Quote Link to comment Share on other sites More sharing options...
hopbin9 Posted July 20, 2012 Author Share Posted July 20, 2012 Thanks Graham, that did the trick! Quote Link to comment Share on other sites More sharing options...
