Debris for prefactured destructions
dark_cry
Hi houdini guys, i'm playing with destructions and firstly need some advise and critique. There is my destruct.hip
, please take a look. But the main question is i want to emit some debris with tiny flying rocks, further some fluid from these points. I've tried to emit from Impact points and i think the impact data is not working at all, may be it's a bug? I also tried Debris shelf tool from Paricles shelf but it is not working as well. I thought may be it works only with dynamically fractured objects, tested out with dynamic fracturing and thats not working as well (though it's not a point for now). Really need directions. Thanks in advance
I haven't looked at your scene but if you use the debris tool off the shelf you can go into the debris node> debris Geometry set up and at the top of that node graph the Object_merge_dop_geo can be changed to read in a cache of your rbd sim rather than the actual simulation as long as it was cached with the "inside" group from the voronoi. not sure what issues you were having with it but that may help
Edited by nMolson
