Help with pcd importer
bandini
I started to write a .pcd importer in python to import files using the point cloud data format (http://pointclouds.org/documentation/tutorials/pcd_file_format.php).
I have xyz position taken care of, but I don't exactly understand how to extract the color information from the file. Hoping someone here can provide a short code snippet.
The documentation indicates that the color is encoded as a packed uint32_t rgba value.
Their packing and unpacking method is easy to see in C++, as described here: http://docs.pointclouds.org/1.3.0/structpcl_1_1_r_g_b.html
However, since I have the packed data written out as an ACSII file, what would be the code needed to unpack that in python?
For instance, just the value 4.2108e+06
How to go about unpacking that into color values? That value comes from the test file in the first link above.
Thanks!
Adam
