Update the help in a digital asset via Python
I'm stuck. I was working on a tool that would assist it writing the help for a bunch of digital assets. I'm able to extract the help to a string using the embeddedHelp method in HDADefinition, but I can't figure out how to save help changes to the HDADefinition. Appears to me this functionality is missing.
Is there an alternative approach to this problem. Is there a way to convert a HDADefinition to code like asCode() or something, where I could do search/replace to update the help.
EDIT: One idea is to expand the OTL to a folder and then modify the Help text file, but that requires refactoring my Python code. So if there is a way to do this inside Houdini that would be much better for me right now.
Edited by hopbin9
Help is just stored in the "Help" asset section. You can easily get/set it.
help_section = asset_definition.sections()["Help"]
# hou.HDADefinition.embeddedHelp() is basically just doing the previous and next line.
contents = help_section.contents()
help_section.setContents("Some new help thing")
