DOPs Point Position not deactivating
watson
Hi Watson.
If you want to use bullet solver, add rbd state dop. Set vel values to $velx $vely $velz similarly set angular vel to $angvelx $angvely $angvelz. Set para operation to set always for vel and angvel para on rbd state dop. You will get the desired result.
or
Simply change the solver to rbd solver. It will start working straightaway.
Bullet solver stops updating velocities when pointpos dop gets deactivated.
