cell multi-division effect
csp
Reference
Hello, any idea or thoughts how to achieve the cell division effect? It should be something like the first video where cells split in two but it has also to be a repeated process as in the second reference (ignore that are bacteria) where the divided cells keep dividing themselves. I tried few things with pops but as you can see it doesn't work that well.
cellstest.hip
Here's something I came up with based on the recursive particle splitting example in the Houdini Help.
I'm using spheres to represent the cells, but metaballs should work with a bit of tinkering.
The first dividing pair is a bit of a hack though. Two original overlapping spheres (first set of two particles) are set to die off while the first pair of dividing and interacting spheres are born. Subsequent dividing pairs seem to behave as expected.
Hope it helps and looking forward to see you finished product ^^
mitosis.hipnc
