Wooshum Posted October 8, 2012 Share Posted October 8, 2012 Hi All! I am wanting to Transform UV coords along V based on time to give the illusion of forward motion (using UV Transform SOP) but am running into a few issues. Knowing the UV space is from 0 - 1 I cant use $F (integer) and even when I use $FF I am not getting a float value returned (is $FF meant to return a float?). Using the ladder to slide the values at 0.1 increments I can see a change in the UV position and with my animation at 2880 frames when I slide somewhere past 2000 my texture turns black. So - Is there a way via expressions I can loop between 0-1 using decimal increments based on time/frames? Cheers! Quote Link to comment Share on other sites More sharing options...
sadhu Posted October 8, 2012 Share Posted October 8, 2012 (edited) Did you try $F/$NFRAMES ? This should give you value from 0 to 1 as you go from frame 0 to frame 2880. If you want to loop then multiply only $NFRAMES by say 0.5 ($F/($NFRAMES*0.5, Choose by what number you want to multiply $NFRAMES to get the desired result) it will repeat twice. You can see the effect of $FF when you go to Global Animation Options and turn of the the integer Frame values and set step == non integer value like 0.1 to 0.9 Edited October 8, 2012 by sadhu Quote Link to comment Share on other sites More sharing options...
