Porting glow shader from RenderMan Companion
nicholas_yue
I am attempting to port the glow shader from RenderMan SL
I am not sure how to handle Cs.
The prman.h header file suggest we pass in the color information via a VEX parameter.
I know how to add a color parameter, my question is, how do we get the color information in the first place.
Cs is defined as the incoming color information.
Here is the glow shader source in RenderMan SL
* glow(): a shader for providing a centered "glow" in a sphere
* From _RC_ Listing 16.26 p. 369
* Surface mapping object-space coordinates to colors
surface
s_RCGlow (float attenuation = 2)
float falloff = I.N; /* Direct incidence has cosine closer to 1. */
if (falloff < 0) {
/* Normalize falloff by lengths of I and N */
falloff = falloff * falloff / (I.I * N.N);
falloff = pow (falloff, attenuation);
Ci = Cs * falloff;
Oi = falloff;
else
Oi = 0;
Once you've created and fed your point attribute ( say Cs or whatever).
In VOP, just add a Parameter VOP, rename it to your point Attribute ( Cs here), and turn on Export Parameter, in the Parameter Page.
The parameter that you defined at specific points will be interpolated on the whole surface.
Hope it answers your question.
#pragma oplabel "NYVEX Glow"
#pragma opname	NYVEX_Glow
#pragma opicon SHOP_surface
#pragma label  attenuation  "Attenuation"
#pragma label  gcolor  "Color"
#pragma hint	attenuation	float
#pragma hint  gcolor  color
#pragma range attenuation 1 20
surface s_RCGlow (vector gcolor = {1.1, 1.1, 0.9}; float attenuation = 2)
   float falloff = dot(I, N); /* Direct incidence has cosine closer to 1. */
   if (falloff &lt; 0) {
       falloff = falloff * falloff / (dot(I,I) * dot(N,N));
       Cf = gcolor*falloff;
       Of = falloff;
   else
      Of = 0;
