~nature~ Posted October 29, 2012 Share Posted October 29, 2012 Hello guys, Nice day! This is my snapshot of my rendering, you can see the artifacts along the edges, I used texture with mantra surface shader (with opacity map applied), Does any one know why?, is it caused by the opacity map? Cheers, Quote Link to comment Share on other sites More sharing options...
dennis.albus Posted October 29, 2012 Share Posted October 29, 2012 I would guess this has something to do with stochastic transparency. Try turning that feature off in the mantra rop under properties>sampling or try increasing the stochastic samples parameter and see if that helps. -dennis Quote Link to comment Share on other sites More sharing options...
~nature~ Posted October 29, 2012 Author Share Posted October 29, 2012 Hi dennis, It works, really appreciate for your help! Cheers, Best regards Quote Link to comment Share on other sites More sharing options...
