Mantra crashes while rendering photon map
Whenever i try to use a GI light in this particular scene, mantra crashes a few seconds after it starts to generate the photon map. The file simply contains a lot of geometry nodes pointing to different obj files and has shaders assigned to them. Since this happens only with this file and the objs are absolutely fine, i am guessing something is going wrong with the shaders. But for the most part, i am clueless.
UPDATE: GI works correctly once all the shaders are disconnected. Hence, it probably is an issue with a shader somewhere.
post-7374-0-72650900-1352167990_thumb.pn
fruit_v2.hipFetching info...
Edited by Ankit Pruthi
