Retrieving a GEO_Point* from GEO_PointPtrArray
Guest xionmark
Guest xionmark
Hello,
I'm confused about retrieving a point from a GEO_PointPtrArray array. The array is getting properly built, verified by a call to GEO_PointPtrArray.display, but when trying to make the assignment to a GEO_Point* variable, mantra crashes. It's got to be something obvious ... !
Code fragment:
GEO_PointTree mySRCPointTree // this actually gets set before this function is called;
GEO_Point * ppt, * inst_ppt;
GEO_PointPtrArray src_list;
GA_FOR_ALL_GPOINTS(inst_gdp, inst_ppt) {
	 UT_Vector3 inst_pos = inst_ppt->getPos();
	 fpreal inst_radius = static_cast<fpreal>(inst_ppt->getValue<fpreal>(myInstAttrRefs.pointRadius, 0));
	 int num_src_pts_found = mySRCPointTree.findAllClosePt(inst_pos, inst_radius, src_list);
	 src_list.display(); // works!
	 if(num_src_pts_found > 0)
		 for(uint i = 0; i < src_list.entries(); i++) {
			 ppt = src_list(i);										 // CRASHOLA!
// 			 fpreal radius = static_cast<fpreal>(ppt->getValue<fpreal>(myPointAttrRefs.radius, 0));
As always, thanks in advance!
--Mark
Edited by xionmark
Guest xionmark
Fixed!
I was using the wrong form of appendPtRadius() to build the point tree list.
For my purposes this was wrong (but valid):
mySRCPointTree.appendPtRadius(ppt->getPos(), radius);
And this is correct:
mySRCPointTree.appendPtRadius(myGdp, ppt, radius);
Never mind! :-)
--Mark
