POP Solver jitter
chrish
Are there any techniques for eliminating the jitter that seems to happen when particles come to rest in DOPs using the POP solver? The POP solver is handling collisions, with bounce active. I'd like the particles to eventually come to rest. RBD Autofreeze does not appear to be a solution in this case.
Thanks,
Chris
Increasing the sampling worked pretty well. Thank you.
Autofreeze doesn't work because the individual particles don't have dop-object-level transform information that the tool can read. Try increasing the substeps on either your doppop or your dopnet, should do the trick.
