Scope issues in Pre/Post render script variables
Jordan Walsh
HI all,
Im wanting to store a value in the in python in the pre frame script (the output directory) assign a local output directory then in the post render script get copy the file that rendered to the original output directory. The problem is I cant access any variable created by the pre frame script in the post frame script.
Nor can I make them global in the render python script or can I access any variables defined in the python render script (te one that calls render)
