GU_Cookie, how to use it?
hi there,
I tried to play around with hdk cookie (GU_Cookie) but it messed up. Basically I did these things in my code:
1. merge in input A and input B
2. create primitive and point groups for both inputs
3. call setGroups to setup groups
4. call cookie for the cookie operation
With my understanding, the output should be in those [in/out/overlap] groups that I can check. But when I used two spheres for testing, the result is totally wrong.
Anyone could give me a hint what I did wrong here?
GU_Detail* input_geo0 = (GU_Detail *) inputGeo(0);
GU_Detail* input_geo1 = (GU_Detail *) inputGeo(1);
GA_PrimitiveGroup* pr_a = input_geo0->newPrimitiveGroup("pr_a");
GA_PrimitiveGroup* pr_b = input_geo1->newPrimitiveGroup("pr_b");
GA_PointGroup* pt_a = input_geo0->newPointGroup("pt_a");
GA_PointGroup* pt_b = input_geo1->newPointGroup("pt_b");
for (GA_Iterator it(input_geo0->getPrimitiveRange()); !it.atEnd(); it.advance())
GA_Offset offset = it.getOffset();
pr_a->addOffset(offset);
for (GA_Iterator it(input_geo1->getPrimitiveRange()); !it.atEnd(); it.advance())
pr_b->addOffset(offset);
for (GA_Iterator it(input_geo0->getPointRange()); !it.atEnd(); it.advance())
pt_a->addOffset(offset);
for (GA_Iterator it(input_geo1->getPointRange()); !it.atEnd(); it.advance())
pt_b->addOffset(offset);
gdp -> merge(* input_geo0);
gdp -> merge(* input_geo1);
GU_Cookie m_cookie;
m_cookie.setGroups(pr_a, pr_b, pt_a, pt_;
GA_PrimitiveGroup* a_in = gdp->newPrimitiveGroup("a_in");
GA_PrimitiveGroup* a_out = gdp->newPrimitiveGroup("a_out");
GA_PrimitiveGroup* a_overlap = gdp->newPrimitiveGroup("a_overlap");
GA_PrimitiveGroup* b_in = gdp->newPrimitiveGroup("b_in");
GA_PrimitiveGroup* b_out = gdp->newPrimitiveGroup("b_out");
GA_PrimitiveGroup* b_overlap = gdp->newPrimitiveGroup("b_overlap");
m_cookie.cookie(*gdp,
0,
*a_in,
*a_out,
*a_overlap,
1,
*b_in,
*b_out,
*b_overlap,
1,
1
[/CODE]
  • 2 weeks later...
one houdini master helped me figured out. In case someone has the same question:
   GU_Detail* input_geo0 = new GU_Detail;
GU_Detail* input_geo1 = new GU_Detail;
duplicateSource(0, context,input_geo0);
duplicateSource(1, context,input_geo1);
gdp->clearAndDestroy();
GU_Detail* gdp1 = new GU_Detail;
gdp1 -> merge(* input_geo0);
gdp1 -> merge(* input_geo1);
GU_Cookie m_cookie;
m_cookie.setTolerance(0.0001);
GA_PrimitiveGroup* m_pr_a = gdp1->findPrimitiveGroup("pr_a");
GA_PrimitiveGroup* m_pr_b = gdp1->findPrimitiveGroup("pr_b");
m_cookie.setGroups(m_pr_a, m_pr_b, 0, 0);
m_cookie.cookie(*gdp1,
0,
* gdp1->newPrimitiveGroup("a_in"),
* gdp1->newPrimitiveGroup("a_out"),
* gdp1->newPrimitiveGroup("a_overlap"),
1,
* gdp1->newPrimitiveGroup("b_in"),
* gdp1->newPrimitiveGroup("b_out"),
* gdp1->newPrimitiveGroup("b_overlap"),
1,
1
GU_Detail *new_gdp = m_cookie.getDetail();
gdp ->merge(*new_gdp);
gdp1->clearAndDestroy();
input_geo0->clearAndDestroy();
input_geo1->clearAndDestroy(); [/CODE]
