Override material parameters
VVV85
Hello!
I'm new with Houdini!
The problem is...when I assign material to object and then click "Create All Local material parameters" parameters does not work for me
so if I change param from material, it's ok
what am I doing wrong?
I have created video to understand it easily
yep! you are absolutely right! on render it has right color )
but I believe it has to work in a right way in viewport too...I just follow the tutorial and it displays correctly there
maybe somesetting in a "D", settings in the videocard I have to change?
