inlinecpp again
resonanz
Hi all!!
After some time fiddling around without success I thought it´s time to ask...
I have a simple C++ function in inlinecpp and would like to use the second imput of the node as const GU_Detail *. But this does not work althought it did in Houdini 11. As long as I use only one GU_Detail, not matter if const or not it works without problems.
Is there something I am doing wrong with the new geometry-library or is it maybe a bug?
code as follow
import inlinecpp
cppModule = inlinecpp.createLibrary(
name = "do_something",
includes = """
#include <GU/GU_Detail.h>
function_sources = ["""
void doSomething(GU_Detail *gdp, const GU_Detail *gdpTemp)
cout << gdp->getNumPoints() << endl;
cout << gdpTemp->getNumPoints() << endl;
cppModule.doSomething(hou.pwd().geometry(), hou.pwd().inputs()[1].geometry())
[/CODE]
Thanks Graham for taking a look!
Yes I am on Windows 7 64bit and the error I get is:
File "C:/PROGRA~4/SIDEEF~1/HOUDIN~1.167/houdini/python2.6libs\inlinecpp.py", line
430, in createLibrary
config=config)
File "C:/PROGRA~4/SIDEEF~1/HOUDIN~1.167/houdini/python2.6libs\hutil\cppinline.py",
line 1182, in create_library
include_dirs, link_dirs, link_libs)
line 293, in __init__
catch_crashes)
line 312, in _load
self._load_existing()
line 373, in _load_existing
getattr(self._library, function.symbol_name()))
File "C:\PROGRA~4\SIDEEF~1\HOUDIN~1.167\python26\lib\ctypes\__init__.py", line 366
, in __getattr__
func = self.__getitem__(name)
File "C:\PROGRA~4\SIDEEF~1\HOUDIN~1.167\python26\lib\ctypes\__init__.py", line 371
, in __getitem__
func = self._FuncPtr((name_or_ordinal, self))
AttributeError: function '?doSomething@@YAXPEAVGU_Detail@@PEBVGU_Detail@@@Z' not fou
nd
[/CODE]
Whatever causes the error it must be new in Houdini 12. When I tried it in Houdini 11 it works without any problems.
