woodenduck Posted January 17, 2013 Share Posted January 17, 2013 Has anyone had any trouble controlling flip particle lifespan using a particle fluid emitter? Does it need some other parameter to be activated in order to work? As far as I can see it has no effect whatsoever on the lifespan of my particles. Quote Link to comment Share on other sites More sharing options...
ikarus Posted January 19, 2013 Share Posted January 19, 2013 Do you have reseeding turned on? the basic life attribute wont work with reseeded particles as new ones are birthing / dying constantly Quote Link to comment Share on other sites More sharing options...
woodenduck Posted January 23, 2013 Author Share Posted January 23, 2013 Hi ikarus, No, I don't have reseeding turned on. Any other thoughts as to what might cause this? I've attached a very simplified .hip file, in case there are any glaring mistakes I've made that you could spot. Cheers, WD flipLifespan.hip Quote Link to comment Share on other sites More sharing options...
bloomendale Posted January 24, 2013 Share Posted January 24, 2013 (edited) Because all pop solvers in Particle Fluid Emitter DOP have their integration step suppressed. So they don't apply new vel, pos, age, up-vector etc. You can turn on "Apply rules" checkbox in the Solver tab of the pop solvers. But i'd also add Suppress rule POP in all chains with all suppressions enabled to get only age attrib integrating. Edited January 24, 2013 by bloomendale 1 Quote Link to comment Share on other sites More sharing options...
woodenduck Posted January 24, 2013 Author Share Posted January 24, 2013 I see, thanks Bloomendale! I've got it working now. Quote Link to comment Share on other sites More sharing options...
