ford77 Posted February 5, 2013 Share Posted February 5, 2013 Hi, I need a deformer to create a banana peel like effect. I`ll have different patches and I need to bend / curl them in a controllable way. For starters, I`m thinking about deforming a line, and using wiredeform to deform the patches. I need help creating the line curling deformer in vops. I attached a hip with the problem. Could anybody help? Thank you, ford Curling VOP v02 - odforce.hip Quote Link to comment Share on other sites More sharing options...
dennis.albus Posted February 6, 2013 Share Posted February 6, 2013 Hey, you should try the qbend deformer which gives you a very nice bend. You can also dive into the asset and take a look at the VOP network which does all the bending work. http://www.sidefx.com/index.php?option=com_wrapper&Itemid=143 Other than that there are also a bunch of deformers available from the orbolt store. -dennis Quote Link to comment Share on other sites More sharing options...
ford77 Posted February 9, 2013 Author Share Posted February 9, 2013 Thanks for the advice Dennis. do you know how to modify that tool like the low and high parameters not only keep that part of the curve straigt, but it keeps the the points on the original position? Quote Link to comment Share on other sites More sharing options...
dennis.albus Posted February 12, 2013 Share Posted February 12, 2013 I'm not sure I understand fully what you mean. If you set your low bound to 0 everything on that side of the bend should stay in its default position. Could you try to elaborate a little bit on what you want to do? -dennis Quote Link to comment Share on other sites More sharing options...
