bend / curl deform line in vop effect help needed
ford77
Hi,
I need a deformer to create a banana peel like effect.
I`ll have different patches and I need to bend / curl them
in a controllable way. For starters, I`m thinking about deforming
a line, and using wiredeform to deform the patches.
I need help creating the line curling deformer in vops.
I attached a hip with the problem.
Could anybody help?
Thank you,
ford
Curling VOP v02 - odforce.hipFetching info...
Hey, you should try the qbend deformer which gives you a very nice bend. You can also dive into the asset and take a look at the VOP network which does all the bending work.
http://www.sidefx.com/index.php?option=com_wrapper&Itemid=143
Other than that there are also a bunch of deformers available from the orbolt store.
-dennis
