setExpression python problem
Xims
Hi, I'm a total noob at python and I need a little help
I'm trying to set an expression on a channel in a node, but the problem is that I need to get this result: point("../Rot", 0, "t", 0) Where the(Rot) can change depending on the Node that is created.
so if it creates a Rot1 I need it to set the expression to: point("../Rot1", 0, "t", 0)
Can anyone help ?
Below is just an example not a working version
hou = hou.node("obj")
Rot = hou.createNode("geo",node_name = "Rot")
transform2 = hou.node("obj/DormerMesh/xform3")
transform2.parm("tx").setExpression()
Something like this should work. I also modified it slightly to point to the display node of your target node, since in this case you can't access information from an Object with a point expression.
node = hou.node("/obj").createNode("geo", "Rot")
xform = hou.node("/obj/DormerMesh/xform3")
expr = 'point("{0}", 0, "t", 0)'.format(xform.relativePathTo(node.displayNode()))
xform.parm("tx").set(expr)
thanks this works perfect
