Rendering with prman
pyrochlore
Hi all,
This is the first time I use Houdini with prman.
So maybe I made a stupid mistake I don't know.
In my test file (in attachment),
I can generate rib using ROP Randerman.
when I type "prman test.rib" in command line,
I can also get the rendered image in mplay.(I have install RmDisplay by proto_install)
But when I try to render it to ip or image file using ROP Renderman, it comes out nothing.
I have checked the Render Manager, and found a job I sent is running without stop.
Even I press the kill button, I can not kill the job I sent.
Please help me fix the problem.
Thanks.
test_renderman_render.hip
Edited by pyrochlore
