VRAY Procedural On Mac
Im trying to test VRAY Procedural samples but they are not working. Im getting nothing rendered and i get no error message.
I compiled DemoBox example and moved it into /Users/alinakipoglu/Library/Preferences/houdini/12.1/dso/mantra/VRAY_DemoBox.dylib
I also have VRAYProcedural File located as
/Users/alinakipoglu/Library/Preferences/houdini/12.1/VRAYProcedural
With demobox DSO_FILE(VRAY_DemoBox) line defined.
I created an Otl with File -> New Operator Type -> Shop Type -> Geometry Shader / Procedural Shader with demobox set in Operator Name, Operator Label and Otl name in library path /Users/alinakipoglu/houdini12.1/otls/demobox.otl
Im adding an empty geo with demobox procedural shader set on render/geometry/procedural shader parameter.
When i check loaded procedurals with manta -V4 i get demobox loaded.
I double checked everything but it seems im missing something here.
Edited by alinakipoglu
