melany Posted February 16, 2004 Share Posted February 16, 2004 hello, apparently z depth in houdini is rendered as a separate image file. Is there any way to render the zdepth along with my rgba image in order to have one whole image? hope this makes sense... thank you Quote Link to comment Share on other sites More sharing options...
Mcronin Posted February 16, 2004 Share Posted February 16, 2004 It renders to a sperate file depending on what format you use. If you use Houdini's .pic format you can have R, G, B, A, Pz, or any other common or user defined custom channel embedded right in the image. Quote Link to comment Share on other sites More sharing options...
