Raw indirect from illuminance loop?
I have a simple shader to export separated indirect and direct image planes.
#pragma hint clr color
#pragma hint direct hidden
#pragma hint indirect hidden
surface
sep_lighting(vector clr = 1;
export vector direct = 0;
export vector indirect = 0)
vector nn = frontface(normalize(N),I);
Cf = 0;
illuminance(P, nn, "categories", "direct")
shadow(Cl);
direct += Cl * clr * dot(nn,normalize(L));
illuminance(P, nn, "categories", "indirect")
indirect += Cl * clr;
Cf = direct;
[/CODE]
But its indirect pass contents direct lighting ([i]/out/mantra1[/i] ROP in attached file):
post-5934-0-72110700-1363344482_thumb.jp
Another shader with Irradiance in Material VOP works perfectly ([i]/out/mantra2[/i] ROP):
post-5934-0-06904200-1363344432_thumb.jp
Mantra also prints warnings about constant and plastic but this shaders are not used here. I even checked the ifd.
Where I was wrong?
sep_lighting.hipnc
