Flip problem
feiyu9903
I'm a new user to houdini flip! i have a problem about flip!
this is a very simple scene,only a sphere and a defalut fluidtank! the sphere is influenced by gravity and fall into the water,but there is only a little spray,the sphere can only a little influence to water. i do the same things in naiad ,the result is nice! is there any parameters to control this in houdini flip? or the sphere is too small? or i have to add a custom field?
flip test.hipnc
Try increasing the velocity (negative value in Y in your case) on the initial state tab of your rbd object dop. Play with density on the physical tab as well. You'll get more of a reaction for sure.
post-6308-0-10068300-1366711306_thumb.pn
Edited by outtacontex
