bloomendale Posted April 26, 2013 Share Posted April 26, 2013 Hi. I'm trying to open Geometry data of the dop object in gas field dop as pointcloud using op: statement. But it doesn't work: for example op:/obj/dopnet1:obj1/Geometry even if you have Geometry won't open any data. But if i import this data in sops via dop import sop and then use something like: op:/obj/imports/dopimport1 in point cloud open VOP it works. But it's slower and i always will get previous frame. I tried relative path with opfullpath, different global variables like $DOPNET, $OBJID. backticks etc.. nothing works. Anybody knows is it possible? I just don't see why it should not work but it doesn't. thanks in advance Quote Link to comment Share on other sites More sharing options...
