bloomendale Posted May 27, 2013 Share Posted May 27, 2013 Hi. 1) I have quite strange behavior in DOPs, using gluenetwork to switch between keyframed/simed positions per object. i attached simple example: there is fractured box, imported as fractured rbd in dops. Added gluenetwork and sopsolver to alter it. Every time point in gluenetwork is deleted i change switchsolver from keyframed position to bullet. BUT. if i have only two solvers feeding in switchsolver (bullet solver and copydata solver to fetch keyframed position) it's not working properly. I ended up with quite strange construction - added couple of useless solvers (red nodes) which i don't need and it works. Just delete red nodes and connect rigid body solver as 1st in switch solver - and you will get weird behavior. 2) What is the reason behind name attrib in Glue Pieces SOP? it is not containing dyn. object name, it's just prefix + $OBJID. And when using default prefixes ("piece") i have misleading name attrib (point which represents dynobject named piece0 with OBJID ==2 has name=="piece2"). thanks in advance. p.s. Hope at least this topic will gather some answers) 3ak_gluenetwork_activation1.hipnc Quote Link to comment Share on other sites More sharing options...
bloomendale Posted May 27, 2013 Author Share Posted May 27, 2013 it seems it's not gluenetwork. it's switchsolver and bullet solver not working properly together. Quote Link to comment Share on other sites More sharing options...
