Mibro Posted June 20, 2013 Share Posted June 20, 2013 (edited) Hey guys, awesome forum! I saw this reel by Jae Hyun Yoo and was blown away. Also there was the effect where the dragons wings created a fiery trail, and at 1:57 there is a breakdown of how it was achieved. I am wondering how to create this traily geometry that slowly deforms from a pop-net, and/or points on a curve. Can anyone help me out? Thanks in advance Edited June 20, 2013 by Mibro Quote Link to comment Share on other sites More sharing options...
old school Posted June 20, 2013 Share Posted June 20, 2013 A lot of way to trail sheets from objects with two common ways: Trail SOP or fixed particle Birth per Frame Trail SOP From your animated object, extract a bit of geometry then construct a line segment from this, resample to a fixed number of points. You can use the Trail to connect the lines (as this is a common thing to do and is exposed as an option) or you can just trail the geometry and use a Skin SOP. Fixed Particle Birth per Frame Similar to the Trail SOP but you replace the Trail SOP with a POP Network SOP with a Source POP set to birth a fixed number of points per timestep. Follow up with an Add SOP to construct lines using a pattern option and then Skin SOP. After that you can build whatever you want on the surfaces. sheet_trail__pops_trail_sop.hip 2 Quote Link to comment Share on other sites More sharing options...
Mibro Posted June 20, 2013 Author Share Posted June 20, 2013 A lot of way to trail sheets from objects with two common ways: Trail SOP or fixed particle Birth per Frame Trail SOP From your animated object, extract a bit of geometry then construct a line segment from this, resample to a fixed number of points. You can use the Trail to connect the lines (as this is a common thing to do and is exposed as an option) or you can just trail the geometry and use a Skin SOP. Fixed Particle Birth per Frame Similar to the Trail SOP but you replace the Trail SOP with a POP Network SOP with a Source POP set to birth a fixed number of points per timestep. Follow up with an Add SOP to construct lines using a pattern option and then Skin SOP. After that you can build whatever you want on the surfaces. sheet_trail__pops_trail_sop.hip That's amazing, just what I was looking for. Thanks a bunch! Quote Link to comment Share on other sites More sharing options...
