Multithreading
I've got the following code which mimicks a trail sop:
SOP_TrailIfExists::cookMySop(OP_Context &context)
fpreal t = context.getTime();
fpreal f = context.getFloatFrame();
fpreal new_t;
const GU_Detail *current_frame_gdp;
const GU_Detail *trail_frame_gdp;
GU_Detail blank_gdp;
GU_Detail trail_gdp;
OP_Context trail_context = context;
//get trail length and increment amount from UI
fpreal len = LEN(t);
fpreal inc = INC(t);
// Lock the input context
if (lockInput(0, context) >= UT_ERROR_ABORT)
return error();
//get the geometry
current_frame_gdp=inputGeo(0, context);
//start copying
gdp->copy(blank_gdp, GEO_COPY_START);
//copy current frame
gdp->copy(*current_frame_gdp, GEO_COPY_ADD);
//unlock the context
unlockInput(0);
//do the trail
for(int i = 1;i<len;i++)
// This is the frame number we want to evaluate
new_t = f-(i*inc);
// The context takes seconds, not frame, so we convert.
new_t = OPgetDirector()->getChannelManager()->getTime(new_t);
// Adjust our cooking context to reflect this
trail_context.setTime(new_t);
if (lockInput(0, trail_context) >= UT_ERROR_ABORT)
return error();
//get the geometry
trail_frame_gdp=inputGeo(0, trail_context);
// copy the geometry
gdp->copy(*trail_frame_gdp, GEO_COPY_ADD);
//end copying geometry
gdp->copy(blank_gdp, GEO_COPY_END);
//unlock the input
unlockInput(0);
return error();
[/CODE]
I'd like to be able to make it run on multiple threads, but I'm a bit unsure about how to go about it. I've had a look at:
http://www.sidefx.co...ingChildThreads
which seems to suggest I need to wrap it all up into a class and use the UT_ThreadedAlgorithm THREADED_METHOD options. But then I looked at the slides in: $HFS/toolkit/slides/HDK12_Intro.pdf
and they mention the UTparallelFor option. My main questions are:
1. Which one should I go for?
2. Will I need to wrap all of my code into a class or can I just put the for loop into a seperate function and thread that function?
Cheers,
Tony
Guest mantragora
If I remember correctly PDF mentioned both methods. It wasn't specified why one is better over other so I suppose both are equally good.
PS. I have somewhere example of threaded code, not made by me, but I can't find it now. :)
Edited by mantragora
I'm skeptical that this could actually be multithreaded. Houdini doesn't really support threaded network cooking which is essentially what this could would be doing. I suppose it's worth a shot, but I wouldn't expect any gains and there might even be some crashing.
