Aeonx21 Posted July 19, 2013 Share Posted July 19, 2013 Hey odforce, I am trying to make a flamethrower and control the how it ignites. My first attempt failed pretty hard. This time around I'm just trying to get the flame to move the way I want and then I will go back to change things to control the ignition. However when I try to run this, the flame appears to go backwards and I'm not really sure why. Here is a clip to show you. The teapot is just a place holder. I have also attached the scene file. Any thoughts? For od.hipnc Quote Link to comment Share on other sites More sharing options...
cenamorado Posted July 22, 2013 Share Posted July 22, 2013 Check inside the pyrosolver sim tab, whats your buoyancy lift at and the direction. Quote Link to comment Share on other sites More sharing options...
JonathanGranskg Posted July 22, 2013 Share Posted July 22, 2013 (edited) Looks like most of it is caused by your shredding. Edited July 22, 2013 by JonathanGranskg Quote Link to comment Share on other sites More sharing options...
Aeonx21 Posted July 22, 2013 Author Share Posted July 22, 2013 Check inside the pyrosolver sim tab, whats your buoyancy lift at and the direction. It was 5 and 0,1,0. I normally leave that alone but I tried playing with it and now its 0,1,1.5. It seems too be helping a lot thank you. I also turned down the shredding a bit too. Thanks. Quote Link to comment Share on other sites More sharing options...
