Renderman in Houdini: how to export "vertex point" attribute?
The question is in the title.
How do I force Houdini to export some point attribute as "vertex point" into rib, not as "varying point"?
I've got a simple setup scene to test how Houdini can export rest positions for renderman shaders:
untitled1.hip
The setup is simple:
  1. I've created the torus
  2. saved it's point positions to "rest" attribute
  3. moved the torus a little up
  4. using "Attribute" node, converted Houdini attribute to Renderman's "vertex point" attribute
  5. and, finally, applied "polygons as subdivisions" attribute to the object
If I render this, I get what I expected:
post-10135-0-01289800-1375197655_thumb.p
Smooth torus, slightly moved up.
Now, what I expect is "rest" attribute should be smoothed the same as P is. And therefore I can get smooth rest positions for furter shading.
To check this, I'm creating a simple shader which displaces points to the rest positions. So I should get smooth torus positioned at the origin. Right?
But here's what I get instead:
post-10135-0-48679800-1375197515_thumb.p
Yes, this is torus. And yes, it's positioned at the origin. But no, it's not smooth.
I've exported the rib to see how it's generated. And here's what I saw there:
post-10135-0-49101700-1375197854_thumb.p
While:
post-10135-0-95751400-1375198041_thumb.p
I've got Houdini 12.5.427, running under 64-bit Win7.
Am I missing something, or it's a bug?
