csp Posted August 1, 2013 Share Posted August 1, 2013 (edited) I have a levelset setup using SDF where blends the geometry of two objects where there is an intersection. But when you animate one of the objects then there is a noise as you play the animation in real time. How can I reduce that? I have attached hip. cheers levelsets.hipFetching info... Edited August 1, 2013 by cparliaros Quote Link to comment Share on other sites More sharing options...
