how to get hou.Geometry from SIM_DopData
rayman
Is it possible?
I want to get gluenetwork solved geometry from relationships data.
It is possible to get this data from DOP to SOP and then to get geometry from there but I`m wondering if there is simpler/faster way?
thanks
Found it!
Just copy SIM_GeometryCopy data to empty object and then access this object.
def createGlueData():
obj = hou.node('.').simulation().createObject("glueGeo",1)
data = hou.node('.').simulation().findRelationship('glueNet').findSubData('gluenetwork/Geometry')
obj.attachSubData(data,"Geometry")[/CODE]
[b]attachSubData[/b]
Make existing data become subdata of this data. Houdini does not create a duplicate of the data. Instead, the data’s parent(s) and this data will both refer to the same instance of subdata. You would call this method from a script solver DOP.
I`m wondering why attaching data to existing objects does not share the same geometry data (I have to attach it every frame otherwise it doesn`t update).
Edited by rayman
