stkeg Posted August 15, 2013 Share Posted August 15, 2013 i'm trying to add new points and primitives to an existing geometry in a DOP with the HDK. this is what I'm doing: //from the SIM_Object i find the object i want SIM_Object *sim_obj = objects.findObjectById(obj_id); const SIM_Geometry* sim_geo = sim_obj->getGeometry(); GU_DetailHandleAutoReadLock gdl(sim_geo->getGeometry()); const GU_Detail *gdp = gdl.getGdp(); gdp->appendPointOffset(); i can't add anything to the gdp. i get errors like this whenever i try (in this example, appendPointOffset): error: passing ‘const GU_Detail’ as ‘this’ argument of ‘GA_Offset GEO_Detail::appendPointOffset()’ discards qualifiers i think it might be because i should be using GU_DetailHandleAutoWriteLock instead of the GU_DetailHandleAutoReadLock, but I can't use the Write version. I get an error like this: error: no matching function for call to ‘GU_DetailHandleAutoWriteLock::GU_DetailHandleAutoWriteLock(GU_ConstDetailHandle)’ any clues as to how i can do this? thanks. Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted August 15, 2013 Share Posted August 15, 2013 (edited) const GU_Detail* mean it's locked for modification and you trying to use non cost function on it. All I can say for now without the code. What you are passing to GU_DetailHandleAutoWriteLock ? Maybe you need to cast it before? It requires const GU_DetailHandle and it looks that you are trying to pass GU_ConstDetailHandle And it's not exactly the same. EDIT: There is a public GU_ConstDetailHandle::castAwayConst() method that returns GU_DetailHandle Maybe you can cast it later to const and pass to GU_DetailHandleAutoWriteLock ? But I'm sure you can get it before without so many casts. EDIT2: You can find example of how to use GU_DetailHandleAutoWriteLock in those three examples in HDK help: http://www.sidefx.co..._c-example.html http://www.sidefx.co..._c-example.html http://www.sidefx.co..._c-example.html Edited August 15, 2013 by mantragora Quote Link to comment Share on other sites More sharing options...
