HDK modifying geometry workflow?
stkeg
is modifying geometry in the HDK mainly about managing the modification of points, vertices and primitives faces yourself?
if i want to split a geometry into 2 (say a box) would i need to create points and vertices and then create the primitive faces?
adding points to an existing geometry might not be a big deal. but if i need to create and manage the faces myself, then i would need to determine if the new points/vertices lie in the same plane as the face so that i can add it to that primitive face.
can i just call some function that would just do this for me (say the break or split poly sop operator)?
Edited by stkeg
