CopyDataDOP
Annon
Anyone used the copyDataDop?
As a simple test I'm trying to add 5 scalar fields, then do stuff to them (say copy density into them and multiply by $CY). But can't seem to get the flow right.
The aim is to add to my go-to solver setup so I can add as many velocity update inputs (or collision/sources etc) as I want based on the number of copies I do.
In the attached example, the gasMatchField will update field_0 but non of the others (I'm presuming because the expression is always returning zero)..
Any help is much appreciated.
Christian
copyData_example.hip
I thought my problem might be about "sharingData".
It seems that I can now get the matchField working but then when I copy density into each field and multiply by $CY I don't get the density changing when I look at the I/O.
No-one seems to know anything about it, so I'll just have to swivel until Jeff & Co turn up to show me how dumb I've been.
Here's the updated scene with me trying to mult density per copy.
C
