gasmatchfield destroys existing field data?
JoshJ
I'm trying to make a custom rest field setup in dops and having trouble understanding gasmatchfield. After initializing a rest field, using gasmatchfield destroys the existing data.
What I would like to have happen is for the rest field to be resized and resampled to match the velocity field's bounds and location, and for the original rest data to be preserved and advected.
Please see the attached file, and bypass the red gasmatchfield node.
simple_advect_rest.hipnc
gasMatchField is going to create or overwrite a field based on another field.
What you want to do is create a new field called "rest_resize", bare in mind this is going to create an empty field the same size/res as whatever reference you use.
So the next thing is to use gas calculate and copy "rest" into "rest_resize".
