Cuckon Posted September 26, 2013 Share Posted September 26, 2013 Hi all, my houdini display volumes well when it was freshly installed, however currently it display any volume in a ugly black messy.. stuff, just like following image. I couldn't tell from when it becomes so weird.. And I have other friends encountered this problem. I tried all the Scenes Render mode, and get no luck to avoid this. Any clue would be appreciated. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted September 26, 2013 Share Posted September 26, 2013 (edited) try changing the display quality by pressing letter 'd' whilst your cursor is over the viewport to bring up the Display Options, then under the Effects tab turn on HDR Rendering and also change the Material Transparency to High Quality. EDIT: also try in Display Option/Geometry Volume Quality settings Edited September 26, 2013 by tar Quote Link to comment Share on other sites More sharing options...
Cuckon Posted September 27, 2013 Author Share Posted September 27, 2013 try changing the display quality by pressing letter 'd' whilst your cursor is over the viewport to bring up the Display Options, then under the Effects tab turn on HDR Rendering and also change the Material Transparency to High Quality. EDIT: also try in Display Option/Geometry Volume Quality settings Hi Marty!!! Changing the Material Transparency to High Quality really solves this problem, You saved my day! Thanks a lot! Quote Link to comment Share on other sites More sharing options...
huangng Posted September 4, 2015 Share Posted September 4, 2015 Amazing You save my life too Cuckon ) Quote Link to comment Share on other sites More sharing options...
