yongbin Posted October 1, 2013 Share Posted October 1, 2013 Hi, houdini dev guys! I am studying hdk and implementing a basic sop. It is similar with polyframe sop. Now I am stuck with calculate average normal on a curve.(like facet sop) There should be a method for this. I find some calculateNormal functions on here and there. But I couldn't figure out which is one and how can I apply it. So, please help me. General advise are also welcome! Thank you. // calculate curve's tangent or N...OP_ERRORCurveAttrib::cookMySop(OP_Context &context){if (lockInputs(context) >= UT_ERROR_ABORT)return error();duplicateSource(0, context);GA_WOAttributeRef tangentRef;tangentRef = gdp->addFloatTuple(GA_ATTRIB_POINT, "tangent", 3);const GA_AIFTuple *tangentAIF = tangentRef.getAIFTuple();GA_RWHandleV3 Phandle(gdp->findAttribute(GA_ATTRIB_POINT, "P"));GEO_Primitive *prim;GEO_AttributeHandle gah;GA_FOR_ALL_PRIMITIVES(gdp, prim){ GA_Range ptrange = prim->getPointRange(); GA_Size npt = prim->getVertexCount()-1; GA_Offset lastpt = prim->getPointOffset(npt); GA_Offset firstpt = prim->getPointOffset(0); bool curve_is_closed = false; fpreal area = prim->calcArea(); if (!SYSalmostEqual(area, 0.0)) { curve_is_closed = true; } for (GA_Iterator iterpt(ptrange.begin()); !iterpt.atEnd(); ++iterpt) { GA_Offset ptoff = iterpt.getOffset(); UT_Vector3 tangent; UT_Vector3 Pcurr; UT_Vector3 Pnext; if ((ptoff==lastpt) && curve_is_closed) { Pnext = Phandle.get(firstpt); Pcurr = Phandle.get(ptoff); tangent = Pnext-Pcurr; //circular } else if ((ptoff==lastpt) && !curve_is_closed) { Pnext = Phandle.get(ptoff-1); Pcurr = Phandle.get(ptoff); tangent = Pcurr-Pnext; //backward } else { Pnext = Phandle.get(ptoff+1); Pcurr = Phandle.get(ptoff); tangent = Pnext-Pcurr; } tangent.normalize(); tangentAIF->set(tangentRef.getAttribute(), ptoff, tangent.data(), 3); }}gdp->notifyCache(GU_CACHE_ALL);unlockInputs();return error();}[/CODE] Quote Link to comment Share on other sites More sharing options...
Stalkerx777 Posted August 9, 2014 Share Posted August 9, 2014 I'll bump this up, because i'm doing the same thing right now To get an average normal for curve, you can use GU_Curve class method curveNormal(). Getting GU_Curve is a little bit tricky: GEO_Primitive *_prim = gdp->getGEOPrimitive(0); GEO_Curve *geocurve = static_cast<GEO_Curve*>(_prim); ((GU_Curve *)geocurve->castTo())->curveNormal(out); Now, my question is: Is there any method/class to compute tangent and bitangent vectors like polyframe sop does? Quote Link to comment Share on other sites More sharing options...
Stalkerx777 Posted August 9, 2014 Share Posted August 9, 2014 Ok, never mind. It looks like it pretty simple. Here is how it's done in Polyframe SOP: Tangent vector = Prev. point position - Next point position Bitangent vector = cross ( Tangent, Curve average normal) P.s. doing some interesting stuff. More question to come. ) Quote Link to comment Share on other sites More sharing options...
yongbin Posted August 15, 2014 Author Share Posted August 15, 2014 (edited) Hi, Stalkerx777. Thank you for answer for this! But I am really a C++ primer. So, all the type conversions break my head. I have questions about the conversions. 1. How can I sure the static_cast (GEO_Primitive to GEO_Curve) is safe? I've heard static_casting base class to derived class may somewhat unsafe. 2. Why did you use castTo() method for GEO_Curve to GU_Primitive? It seems they don't make any relationship in perspective of class hierarchy. Is it possible to conversion? 3. Why did you use (GU_Curve *) instead of static_cast<GU_Curve *>, although (GU_Primitive -> GU_Curve) looks similar to (GEO_Primitive -> GEO_Curve). It is hard to understand about C++ conversion even if I've read some documents about type conversion on web. (In C++, usually class hierarchy is too big and have so many conversion methods!) Thanks in advance! Edited August 15, 2014 by yongbin Quote Link to comment Share on other sites More sharing options...
Stalkerx777 Posted August 15, 2014 Share Posted August 15, 2014 (edited) I'm not a c++ programmer, so sometimes i try a lot of things, before something get to work. Same with casting. One is old C style, other is c++ style. ((GU_Curve *)geocurve->castTo())->curveNormal(out); I'm also not able to cast this into a variable. But i'm not tried this whit static_cast.. Maybe it works. castTo() is a special method to get GU_* type classed from GEO_*. Try to google on c++ type casting. There is a lot of good articles. http://msdn.microsoft.com/en-us/library/c36yw7x9.aspx Edited August 15, 2014 by Stalkerx777 Quote Link to comment Share on other sites More sharing options...
yongbin Posted August 15, 2014 Author Share Posted August 15, 2014 Thank you for your kind reply! The page looks like a great article! I will look into it! Quote Link to comment Share on other sites More sharing options...
