hou.InteruptableOperation outside of a with statement?
glassman3d
Hi there
I am trying to create a generic progress bar so have been looking at hou.InteruptableOperation
My conundrum is that due to in-house generic pipeline tools that implement this for all packages (including maya and softimage), I need to separate out the progress bar into 3 stages:
Creation
Update
Exit
The docs state not to call this class unless I am within a ‘with’ statement. This makes the separation of these stages very difficult
I am attempting to call the __enter__ and __exit__ methods directly but am not having much luck
Could someone give me a pointer about how to achieve this?
Many thanks!
answer from SESI:
Hello Sam,
It sounds like you should set the long operation name/message in hou.InterruptableOperation in order to update the progress bar dialog with message updates.
For example:
# Create an interruptable operation.
operation = hou.InterruptableOperation("Doing Work", long_operation_name="Starting Tasks", open_interrupt_dialog=True)
# Start the operation. This will pop-up the progress bar dialog after a second or two.
operation.__enter__()
# Execute tasks. Periodically update the progress percentage and message in the progress bar.
num_tasks = 10
for i in range(num_tasks):
# Do task work here. For this example, just sleep for a second.
time.sleep(1)
percent = float(i) / float(num_tasks)
operation.updateLongProgress(percent, "Finished task %i" % (i + 1))
# Stop the operation. This closes the progress bar dialog.
operation.__exit__(None, None, None)
I hope this helps.
