hdk sop_node retrieve parameter value???
i'd like a custom sop_node retrieve parameter values by using the hdk. the custom sop_node has a bnuch of float vector parameters.
i guess i need a op_parameter object, but i'm not clear as to how to get that object within the sop_node hdk context.
i have access to gu_detail gdp within the sop_node cookMySop function.
any ideas?
Edited by stkeg
