Macha Posted October 25, 2013 Share Posted October 25, 2013 (edited) I'm having trouble compiling some stuff on OSX 10.9. I can get this work on Linux, and I'm pretty sure I've done it before on a mac. I can compile standalone examples with custom, but the SOP plugins give me errors. For example, the star sop returns this on running hcustom SOP_Star.C (I have write permissions): Making SOP_Star.o and /Users/macha/Library/Preferences/houdini/12.5/dso/SOP_Star.dylib from SOP_Star.Cclang: warning: argument unused during compilation: '-rpath,@loader_path/Libraries'Undefined symbols for architecture x86_64:"OP_Parameters::savePresetContents(std::__1::basic_ostream<char, std::__1::char_traits<char> >&)", referenced from: vtable for HDK_Sample::SOP_Star in SOP_Star.o"OP_Node::saveCommand(std::__1::basic_ostream<char, std::__1::char_traits<char> >&, char const*, double, double, char const*, OP_SaveCommandOptions const&)", referenced from: vtable for HDK_Sample::SOP_Star in SOP_Star.o"OP_Node::saveIntrinsicCommand(std::__1::basic_ostream<char, std::__1::char_traits<char> >&, char const*)", referenced from: vtable for HDK_Sample::SOP_Star in SOP_Star.o"OP_Node::saveDialogScriptExtraInfo(std::__1::basic_ostream<char, std::__1::char_traits<char> >&)", referenced from: vtable for HDK_Sample::SOP_Star in SOP_Star.o"SOP_Node::saveIntrinsic(std::__1::basic_ostream<char, std::__1::char_traits<char> >&, OP_SaveFlags const&)", referenced from: vtable for HDK_Sample::SOP_Star in SOP_Star.o"SOP_Node::saveCookedData(std::__1::basic_ostream<char, std::__1::char_traits<char> >&, OP_Context&, int)", referenced from: vtable for HDK_Sample::SOP_Star in SOP_Star.o"SOP_Node::save(std::__1::basic_ostream<char, std::__1::char_traits<char> >&, OP_SaveFlags const&, char const*)", referenced from: vtable for HDK_Sample::SOP_Star in SOP_Star.o"OP_Node::dumpMicroNodes(std::__1::basic_ostream<char, std::__1::char_traits<char> >&, bool, int) const", referenced from: vtable for HDK_Sample::SOP_Star in SOP_Star.o"OP_Node::executeCommand(char const*, std::__1::basic_ostream<char, std::__1::char_traits<char> >*, std::__1::basic_ostream<char, std::__1::char_traits<char> >*) const", referenced from: vtable for HDK_Sample::SOP_Star in SOP_Star.o"___sincos_stret", referenced from: HDK_Sample::SOP_Star::cookMySop(OP_Context&) in SOP_Star.old: symbol(s) not found for architecture x86_64clang: error: linker command failed with exit code 1 (use -v to see invocation)Link failed[/CODE] Edited October 25, 2013 by Macha Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted October 25, 2013 Share Posted October 25, 2013 i'm not on mac but have you tried google ? http://stackoverflow.com/questions/8034568/undefined-symbols-for-architecture-x86-64-which-architecture-should-i-use Quote Link to comment Share on other sites More sharing options...
Macha Posted October 26, 2013 Author Share Posted October 26, 2013 The makefiles are not including the necessary libraries? Does anybody with maverick have this problem too? Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted October 26, 2013 Share Posted October 26, 2013 (edited) Ups, I missed that you used hcustom. EDIT: But you could post you make file. Maybe there is something wrong with them? Edited October 26, 2013 by mantragora Quote Link to comment Share on other sites More sharing options...
Macha Posted October 26, 2013 Author Share Posted October 26, 2013 (edited) I suppose hcustom uses the toolkit/makefiles. I tried to make my own makfile as in the hdk doc examples and I get the same errors. I think some of the include files in the source code are not being linked against. hcustom should work out of the box, as it does on linux. I can only think that my update to maverick messed up some stuff. Oh, why do I always feel so optimistic by shiny new updates, they usually f*** things up. Should have waited a few weeks I guess... Edited October 26, 2013 by Macha Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted October 26, 2013 Share Posted October 26, 2013 OK, it's 8AM and I still haven't slept so I'm talking nonsense . Hcustom doesn't use make files. But if you are getting the same errors with make file it's a task for SESI guys . Cheers. Quote Link to comment Share on other sites More sharing options...
Zach Posted October 26, 2013 Share Posted October 26, 2013 Are you using the clang build or the gcc build of Houdini? Did you reinstall after upgrading to 10.9? Quote Link to comment Share on other sites More sharing options...
Macha Posted October 27, 2013 Author Share Posted October 27, 2013 I use clang. I also updated Xcode and its command line tools. Quote Link to comment Share on other sites More sharing options...
Zach Posted October 28, 2013 Share Posted October 28, 2013 I wish I could help you. I'm still on 10.7 for reasons like this If you haven't reinstalled Houdini since upgrading, maybe give it a shot... I imagine the environment it sets up must be specific to the operating system version; maybe it's looking at the wrong libraries... I'm sure you've tried all this, though. Quote Link to comment Share on other sites More sharing options...
ophiuchus42 Posted October 28, 2013 Share Posted October 28, 2013 (edited) I get the exact same thing with a clean install of Mavericks and a fresh download of houdini 12.5.533. I'm just going to throw this out there since I'm away from my mac atm and can't try it, but after reading this: http://mathematica.s...vericks-upgrade it looks like the problem might be with the std library version that houdini is linked against. OS X has both libc++ and libstdc++ and they aren't compatible. 10.8 used libstdc++ and 10.9 uses libc++. Try using this flag "-mmacosx-version-min=10.8" since I think that's the version that was used to build the latest houdini or add "-stdlib=libstdc++" to the linking command. Peter. EDIT: I confirmed that this works by adding "-mmacosx-version-min=10.8" to BOTH compile and link. Edited October 29, 2013 by ophiuchus42 Quote Link to comment Share on other sites More sharing options...
Macha Posted October 29, 2013 Author Share Posted October 29, 2013 Peter, where do you set those flags? Quote Link to comment Share on other sites More sharing options...
ophiuchus42 Posted October 29, 2013 Share Posted October 29, 2013 You can make hcustom echo the commands it's running by using the -e option. i.e. "hcustom -e SOP_Star.C". Now before the link error you'll see the two commands it's running (both of them g++ commands). I just copied these two lines, added the "-mmacosx-version-min=10.8" option to them, and ran them directly in the terminal. To avoid running this manually I suppose you could patch hcustom (it's just a shell script) or switch over to using makefiles. I'll submit a bug report to SESI later today about this. They might have some alternative method of working around the issue. Quote Link to comment Share on other sites More sharing options...
Macha Posted October 29, 2013 Author Share Posted October 29, 2013 Thanks, that appears to work! Quote Link to comment Share on other sites More sharing options...
Pharos Posted September 6, 2014 Share Posted September 6, 2014 I'm trying to setup xcode project too. Already spent 2 days but no luck yet. Xcode 5.1.1, mac os 10.9.4. Tried all possible approaches: OS X Deployment Target 10.8 Other linkers flag -stdlib=libstdc++ and -lstdc++ if different combinations Other C and C++ Flags both contain -mmacosx-version-min=10.8 C++ Language Dialect and C++ Standard Library in all combinations I can't even imagine what I missed. Quote Link to comment Share on other sites More sharing options...
