Skip rendered frames script or flag?
Hello guys..
i´m seeking for "Skip rendered frames" option on Houdini, like Skip Frames per Pass on XSI...
there are this option, or need pre-render/pre-frame script? if it is the case, this script already exist in some place to download?
the frame range is not a solution, because i need skip a random rendered frames..., so i need "check" if frames exist before, and skip...
thanks in advance.
