parfin Posted November 18, 2013 Share Posted November 18, 2013 Hallo! Please help me with modelling Domino. I learn Lesson 11 "Dynamics" in "First Steps Intro" and made 28 Domino objects. Then i made export trough ROP output driver. But i can't make random import these domino-files. I don't know, what variable parameter to use. Alexander Parfentyev parfin@list.ru Quote Link to comment Share on other sites More sharing options...
Sierra62 Posted November 18, 2013 Share Posted November 18, 2013 Here is a sample file on how to copy random geometry to points. I hope this helps copy_points.hip Quote Link to comment Share on other sites More sharing options...
parfin Posted November 19, 2013 Author Share Posted November 19, 2013 I thank you very much. But wenn I use Copy, I kan't make RBD object from random geo objects. Quote Link to comment Share on other sites More sharing options...
Sierra62 Posted November 19, 2013 Share Posted November 19, 2013 if you set them up as packed primitives (use the "RBD points" shelf tool) then with the copy SOP it will work just fine. Quote Link to comment Share on other sites More sharing options...
parfin Posted November 19, 2013 Author Share Posted November 19, 2013 i got it. Thanks! Quote Link to comment Share on other sites More sharing options...
