Translate handles disappear when using the Edit SOP
jim c
Sometimes when I use the Edit SOP (with any of the H12 versions, and possibly older too, not 100% sure though), maybe I switch to the sculpt mode, do some sculpting, then switch to the "normal" edit mode and the handles (for T, R, or E) will flicker into view for a second and then disappear. Is there some way to get them to "stick"? Restarting Houdini doesn't seem to make a difference, probably something silly I've done, but I can't figure out what the deal is.
can you check under the Show Handle tool to see which options have checkboxes next to them. i.e. some of those do seems to not be checked sometimes when the handles are not visible.
post-8321-0-49840500-1385761777_thumb.pn
Edited by tar
