Dispel Posted December 1, 2013 Share Posted December 1, 2013 So I have a static object, which I constrained a cloth object to, using the new FEM cloth solver stuff. I've been using the shelf tools.. As soon as I constrain one object to another, my sim time goes through the roof. Like from 30 seconds a frame to 60+ minutes per frame. Having watched the SideFX cloth masterclass, it never seemed like the constraints affected performance much. Any ideas for me here? Quote Link to comment Share on other sites More sharing options...
Guest tar Posted December 1, 2013 Share Posted December 1, 2013 (edited) Not sure exactly what you're doing 17fps processing time for a cloth grid 'stitch'Cloth' to a Static Object torus. Latest build CLothSim.hip Edited December 1, 2013 by tar Quote Link to comment Share on other sites More sharing options...
Dispel Posted December 1, 2013 Author Share Posted December 1, 2013 What is supposed to be the major difference between using a cloth-stitch-constraint and cloth-attach-constraint? I'll try a stitch constraint instead. I was using the "cloth attach" shelf button, unawares that stitching might yield better performance. Quote Link to comment Share on other sites More sharing options...
Dispel Posted December 1, 2013 Author Share Posted December 1, 2013 also, when I use the stitch cloth tool, I get an error complaining about "invalid literal for int() with base 10: " "Traceback (most recent call last): File "dop_stitchconstraint", line 5, in <module> File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.21/houdini/python2.7libs\dopclothtoolutils.py", line 906, in createClothStitchConstraint constrainedPTgroup) File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.21/houdini/python2.7libs\dopsbdtoolutils.py", line 477, in generateSBDAttachmentGoalPTGroup constrainedPTgroup): File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.21/houdini/python2.7libs\dopsbdtoolutils.py", line 64, in selectedPointNumbers return [ int(pt) for pt in pts.split(" ") ] ValueError: invalid literal for int() with base 10: '' Quote Link to comment Share on other sites More sharing options...
Guest tar Posted December 1, 2013 Share Posted December 1, 2013 (edited) The internal difference is the 'goal surface' node in the Stitch Cloth uses points and the Attach to Body 'goal surface' uses primitives groups it appears. I'm not sure which tool is the "cloth attach" shelf tool though, that one isn't in the Cloth shelf here. What is supposed to be the major difference between using a cloth-stitch-constraint and cloth-attach-constraint? I'll try a stitch constraint instead. I was using the "cloth attach" shelf button, unawares that stitching might yield better performance. The Stitch Cloth shelf tool is working on OsX 13.0.248. Might be worth logging a bug with SideFX. also, when I use the stitch cloth tool, I get an error complaining about "invalid literal for int() with base 10: " "Traceback (most recent call last): File "dop_stitchconstraint", line 5, in <module> File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.21/houdini/python2.7libs\dopclothtoolutils.py", line 906, in createClothStitchConstraint constrainedPTgroup) File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.21/houdini/python2.7libs\dopsbdtoolutils.py", line 477, in generateSBDAttachmentGoalPTGroup constrainedPTgroup): File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.21/houdini/python2.7libs\dopsbdtoolutils.py", line 64, in selectedPointNumbers return [ int(pt) for pt in pts.split(" ") ] ValueError: invalid literal for int() with base 10: '' Edit: Also just tested the Attach to Body and have the same speed processing - 19fps on the attached file. AttachToBody.hip Edited December 1, 2013 by tar Quote Link to comment Share on other sites More sharing options...
Dispel Posted December 1, 2013 Author Share Posted December 1, 2013 I've been on 13.0.198, I'll see if moving up a version fixes it. Quote Link to comment Share on other sites More sharing options...
Dispel Posted December 1, 2013 Author Share Posted December 1, 2013 Preliminary result, but moving to the new version seems to make at least one of my cloth attach constraints simulate MUCH faster. In fact, the impact of the constraint is barely noticeable now, I'm finding. Adding on the other constraints shortly. Quote Link to comment Share on other sites More sharing options...
Dispel Posted December 1, 2013 Author Share Posted December 1, 2013 Looking at the bug fixes on the sidefx website, I find this: Tuesday, November 5, 2013 Houdini 13.0.225: Fix for slowdown that sometimes occurred when the finite element solver runs out of linear solve iterations. I'm guessing this is the culprit, as I was getting a warning to the effect of running past the linear solve limit. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted December 1, 2013 Share Posted December 1, 2013 Great! The SideFx are rad and daily builds rock! Quote Link to comment Share on other sites More sharing options...
