harima Posted January 14, 2014 Share Posted January 14, 2014 Hi All I was following the bullet masterclass for Houdini 13 from Sidefx site. At one of the examples he goes and set a spring constraint network for a wall, then a torus hits the wall so when force is above a certain threshold he breaks the network from a sop solver using a force attribute ( he says the solver creates for him). So as I am a fairly new Houdini user I am having some troubles. There is no shelf tool to create a spring network, only glue. So I went ahead and did that and then changed attribute wrangle in the constrain network SOP from Glue to Spring. I also changed the DOP node from Glue Constraint Relationship to a Spring Constraint Relationship with a Dataname of Spring. All looks ok and indeed I have springs working only problem is when I dive to Geometry Details for Constraint Network I obviously dont have force attributes as he has in his ready made example. So I cant make use of a SOP Solver to delete bonds base on force attribute. Question is: How do I go about creating some force attributes? Hope its clear! Thank you all Quote Link to comment Share on other sites More sharing options...
harima Posted January 14, 2014 Author Share Posted January 14, 2014 Sorry guys apparently I do have. I was checking first frame on details view. When I go ahead and play force and distance attributes do populate the Geometry details tab Quote Link to comment Share on other sites More sharing options...
